Home > Faults & Fixes > RR sport 2011 door trim / door moulding
Hunvaakaren
Hi.
Can anyone help me here?
Seems like the clips on the door moulding is broken. How do i remove the trim?
I have new clips available.
Thank you for your time. I have been searching on the Internet but i cant find the correct answer how to do it.
See pictures:
[URL=]
[/URL]
[URL=]
[/URL]
[URL=]
[/URL]
Post #499080 Mon Jun 20 2016 3:15pm
mcox42
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Hunvaakaren,
Where did you buy the clips from and how much? I need to get some of these as well.
Only thing I've found on removal was this...http://www.rrsport.co.uk/forum/topic26951....trim+loose
Martin
Post #499998 Fri Jul 01 2016 12:58pm
Wayneclarke
look on youtube by people called powerful.co.uk I'm sure they done a video
Post #500016 Fri Jul 01 2016 6:20pm
SH0X
I got them off ebay - took ages of searching to find them I think they were under automotive clips or the like
The door molding pulls off, harsh pull but I think there is one screw on them just have a cleanup first then check as sometimes the screw is under dirt and you dont realise
The clips can be pushed out with screw driver I think or just break them out if you are replacing
Post #500060 Sat Jul 02 2016 7:06pm
It's only the Rear Doors that have a screw on the back edge.
Post #500066 Sat Jul 02 2016 8:31pm
