Home > General > 2007 RRS 4.2 super charged
bagsport
United Kingdom 2007 Range Rover Sport Supercharged HSE Java Black
Hi there,
We've just bought a 2007 4.2 hse, couple of sensor issues keep triggering alarm, bonnet, tailgate etc, c So firstly what's the fix and can I do it myself and secondly can I lock the car without setting the alarm as a temporary measure?
There is no key slot on the outside of the car so can't lock with the key rather than remote.
Please help
Thanks
Post #498985 Sun Jun 19 2016 9:51am
There is an emergency key slot in the passenger door handle under the cover.
The bonnet catch is easy DIY and a new catch is cheap. It's a common problem. 2012 SDV6 - it's missing a couple of cylinders
Post #498991 Sun Jun 19 2016 10:39am
Try unplugging the bonnet switch.
It is in the drivers side catch.
I think if you press lock on the remote twice it disables ultrasonics.
Pressing it 3 times does something too.
Read the manual
Post #499000 Sun Jun 19 2016 11:31am
bagsport
Thanks all, will try the sensor myself. Irritatingly I now have had a reduced engine performance message and engine going in to limo mode, turn off and on and works again. I've read it may be super charger pump, how easy a fix is that or is it one one the garage?
Post #499701 Tue Jun 28 2016 7:03am
xanda
I had the reduced performance. Very easy DIY fix to switch the wiring around, there is a tutorial on here somewhere. That said I would recommend getting it replaced and the wire switched at the same time. It's probably been running backwards for almost 10 years Smile
I paid £80 for the pump
Post #500168 Tue Jul 05 2016 10:13am
