![]() | Home > General (L494) > ANYONE GETTING 70+ MPG FROM A L494 HSE? |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
Downhill gradients are your friend.................. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
challigan Member Since: 26 Mar 2008 Location: Highlands Posts: 60 ![]() ![]() |
I have a 63mpg showing on my Fuelly system for the RRS and I cannot explain it - havenn't used the InControl fuel register in ages though as the system seems to forget my password every time there is an IOS update.....
NTBeyond Member Since: 03 Nov 2010 Location: Darwin Posts: 28 ![]() ![]() ![]() |
Over the new year I went to visit my Mum in Victoria and called in on one of my sons in Noosa (QLD).
The only way to get correct results, is not using the computer. You must fill your tank and do your journeys, writing down start and stop mileages. then refill to top again, after a couple of Brim to Brim tests, you will get your true mpg figure. John
I do exactly that, and the answer is, over 9k miles:
eddkawasaki Member Since: 23 Feb 2015 Location: Lancashire Posts: 93 ![]() ![]() |
according to fuelly I'm getting an average of 26.9 mpg over 9.3K. my best tank was 31.2 and this was as an experiment i put the terrain response in GGS. |
I bet you only tried that the once Edd, the pull away will have been rather slow!
to be honest it was not that bad once you get used to it |
