Home > Maintenance & Modifications > Sprint booster
Morgi27
Sprint booster
Hi guys
I've seen various vids on you tube about device.called sprint booster which connects to throttle pedel and stops any.lag
And gets off mark quicker
Anyone used these at all ?
Post #498666 Tue Jun 14 2016 10:01pm
Morgi27
No one?
Post #498690 Wed Jun 15 2016 8:57am
Paddi
Seen this discussed on other forums and it can be described as an electronic box of tricks that simply makes the accelerator pedal more sensitive; I.e. for a given movement of the pedal the throttle opens a bit wider than it would without the gadget fitted.
So an utter waste of time and money since you can achieve the same thing by just pressing the pedal a bit further. 2008 MY Java Black TDV8 HSE
Post #498699 Wed Jun 15 2016 10:24am
scousefly
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
I Have
Never understood these type of questions. Its a 2-2.5 tonne SUV not a sports car if its not responding quick enough I think a new car is in order Confused
Post #498873 Fri Jun 17 2016 3:17pm
