Home > General > facelift headlights failed MOT (euro spec) what todo now... |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
Could you not put your old lights in to get you through the MOT while considering your options and/or saving up for a few months ? |
Tue Jun 14 2016 3:16pm |
Down&Dirty Member Since: 31 Dec 2015 Location: Somewhere out back Posts: 92 |
Or this from topix
Tue Jun 14 2016 3:18pm |
lamb190 Member Since: 12 Jun 2015 Location: bristol Posts: 80 |
just to clarify ive changed the wings and many other parts to a 2012 spec so my old lights if i had them would not fit.
Tue Jun 14 2016 3:23pm |
Call Dan@Duckworths and ask what deal he could do for you on a set of OEM, then if the price is OK fit them BUT make sure that you don't damage the packing cases and retain them, put your removed ones up for sale as Euro Spec on the forum For sale section............... The cost will be high, the packaging is complex, but you can still sell on your unrequited set.
Tue Jun 14 2016 3:50pm |
thanks Tim.
Tue Jun 14 2016 4:59pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
Don't understand why you can't just set the light to be in RHD mode rather than euro LHD. It's just a lever in the headlight unit. 2012 SDV6 - it's missing a couple of cylinders
Tue Jun 14 2016 8:18pm |
i cant find any lever to adjust.
Tue Jun 14 2016 9:09pm |
designboy Member Since: 03 Feb 2014 Location: whitehead co antrim Posts: 338 |
Im wanting to do what you done, what a class looking upgrade man. Hope you can fix the lamps easy with a toggle rather than buy new ones. Surely there is a manual on swapping the beam over? |
Tue Jun 14 2016 9:21pm |
Thanks designboy.
Tue Jun 14 2016 11:19pm |
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1827 |
Well i have a 11mdl AB LHD that has the euro lights and have no problem with the MOT. To adjust the beam there should be white plastic screws that you put a screw driver in towards the back of the light.
Tue Jun 14 2016 11:21pm |
Haven't got a handbook to hand, but I know it gives complete procedure for this in there. John
Wed Jun 15 2016 12:01am |
johnski if you could find out and let me know that would be really helpful.
Wed Jun 15 2016 1:33am |
are the l322 headlights the same set up as the l320 (face lift) as this vid shows how to adjust, I swear I don't have this lever behind the bulb
Wed Jun 15 2016 1:51am |
I removed my headlight today and removed the xenon bulb to look inside, there really is NO lever to move to change the beam pattern. there is only the shutter that open (I think for mean beam)
Wed Jun 15 2016 3:57pm |
