![]() | Home > General (L494) > Gear hesitancy |
Yes my 2012 does it & it's annoying.
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
Still happens.
dazzpowder Member Since: 08 Feb 2006 Location: England Posts: 18 ![]() |
Interesting, but I was told it doesn't exist on the Petrol variants, they must use the same switch. is that true, petrol version font have the issue? |
GJW1 Member Since: 19 May 2015 Location: UK Posts: 447 ![]() ![]() |
My 3.0 has it exactly as you describe it. Havent tried the other models either but ive also read the petrol doesn't have it but haven't tried one myself so cant comment real world. If you drive the 3.0 in dynamic sport it doesn't do it though so I think its a lazy gearbox or how its setup for smoothness that causes it so many computers but still not perfect. |
A good point, well made. All I can say is that the hesitancy seems to vary before/after a brake light switch swap form reports I have seen on the Jag forums.. On my first Jag, if you touched the brake at the same time as being on the throttle, it immediately chopped the throttle totally. The second didn't do this, at least not immediately. This could be software I guess. I can only compare the two Sports I have driven extensively to date - my own and the current loaner - and they vary to a great degree in terms of this "reapplied throttle hesitancy". All the JLR petrol cars I have driven have been supercharged, and they have had exemplary throttle response, in fact so good my next car definitely won't be diesel as I am fed up with "driving around" this "characteristic". MY2016 HSE D SDV6 - gone due to fuel dilution problems. By the age of 50 you have the face you deserve - George Orwell. |
Could the difference between the petrol and the diesel be down to the Supercharger blowing all the time and the turbo needing some time to spool up? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Almost certainly.
