Home > Technical > Vibration |
Stecla Member Since: 20 Jun 2015 Location: Newbury Posts: 157 |
Sorry, I forgot to add. Has quite significant judder when braking at speed. 2010 TDV8 |
Sat May 28 2016 11:18am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
Check the wheel nuts are tight. I had a similar vibration recently - very severe shudder through the car - and it turned out to be a wheel with loose nuts. No idea how they get loose though. If yours has recently had work done then they might need tightening. 2012 SDV6 - it's missing a couple of cylinders
Sat May 28 2016 7:45pm |
Thanks. I will check them this morning. I had a mechanic take it out. He said it feels vague and wollowy, and crashes through every bump (which has at least confirmed its not just in my head). It's like there is nothing suppressing the bumps in the road and it certainly isn't driving as one of these should. I'll take it back into Rovertune next week. At this rate, I'll be getting shares in the place, and being honest I'm tempted to cut my losses and get rid of the car. In 25 years my cars have never been in a garage apart from servicing. I've had this 11 months and it's been in 4 times! 2010 TDV8 |
Sun May 29 2016 7:02am |
As an update to this, I had the car back at rovertune and they kept it a day or two. Couldn't find anything wrong but balanced the rears again and said everything ok.
Sun Jun 12 2016 5:25pm |
To correct, the air 'pfft' comes from driver rear wheel area and happens every 10 seconds. Failing compressor, or is that normal? Would that have any impact on the ride quality issues I've had at all?
Sun Jun 12 2016 6:25pm |
Anyone got any thoughts at all?
Mon Jun 20 2016 6:08am |
