Home > In Car Electronics > 2005 AUX sound quality
HS66
2005 Range Rover Sport TDV6 SE Bonatti Grey
I use the AUX cable into my iPhone sometimes but the sound quality is pretty awful, it's so quiet!!, is this just a common thing with the AUX connection or could it be down to my cable?.
Post #498493 Sun Jun 12 2016 10:57am
Jaggs
Not sure if it makes a massive difference but do you have volume turned up full on the phone and then control volume by stereo
You only get out of the car stereo what goes in so if the output from earphone socket on phone is low so will the stereo Nanocom Evo
Post #498496 Sun Jun 12 2016 11:37am
Bodsy
Site Sponsor
It's a bit rubbish as its got a controller behind the aux input.
You can wire directly to the aux input cables, effectively bypassing the unit. Improves the quality no end. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #498501 Sun Jun 12 2016 12:37pm
HS66
How do you go about wiring directly to the AUX cables?
I do have the volume on both the phone and the car up to full and it's still quiet.
Post #498530 Sun Jun 12 2016 5:05pm
Bodsy
Site Sponsor
Either tap into the red/blue/black wires behind the passenger side kick panel, or directly to the wires going into the back of the radio. Thumbs Up Bodsys Brake Bible
See it HERE
Post #498581 Mon Jun 13 2016 8:57pm
TheWojtek
Can it be removed from the stock AUX location so the wires go directly from the socket to the radio, bypassing the controller? Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #498588 Mon Jun 13 2016 10:28pm
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
Easier fix for iPod- get a lead that's got the wide iPod connector on one end and the headphone jack on the other end- sound quality is perfect.
Post #500875 Fri Jul 15 2016 6:01am
