Home > Maintenance & Modifications > Leaky sunroof
LJRH
Leaky sunroof
Evening all,
My sunroof has been leaking from the rear and I'm guessing it's just a worn seal as the rubber looks quite tired. Does anyone know if you can just buy the rubber trim? I've had a look around but no luck so far.
Cheers guys[/b]
Post #498320 Thu Jun 09 2016 4:41pm
Johnski
Can't help there, but to make things easier to look up for you, please add your vehicle details in your profile, thanks. Wink John
Post #498349 Thu Jun 09 2016 8:55pm
LJRH
Ah I apologise, I thought I had.
It's a 2006 supercharged.
Post #498356 Fri Jun 10 2016 7:18am
LJRH
Anyone?
Post #498399 Fri Jun 10 2016 7:39pm
Paddi
Probably best to order seals from your Land Rover dealership or better still site sponsor Duckworth parts. Call Dan and give him your VIN number to ensure you are supplied with the correct parts.
But make sure you don't just have blocked sunroof drains first - have a look at this TSB in my gallery:
http://www.rrsport.co.uk/gallery/albums/us...9%20~0.pdf 2008 MY Java Black TDV8 HSE
Post #498438 Sat Jun 11 2016 11:54am
LJRH
I'm unsure if a blocked drain is the issue.
I noticed it when going through a car wash, water was streaming through the rear of the glass. Yes it was fully closed..
Post #498440 Sat Jun 11 2016 12:12pm
Paddi
If it is not a blocked drain - which seems to be a very common problem; then the outer seal may have shrunk with age.
The outer seal when working correctly reduces the ingress of water to a rate at which the drains can cope with. If the seal has shrunk then the rate of ingress overwhelms the drains and the channel around the roof aperture fills up and overflows into the cabin. 2008 MY Java Black TDV8 HSE
Post #498441 Sat Jun 11 2016 12:43pm
LJRH
And I can order the outer seal by itself?
Post #498442 Sat Jun 11 2016 12:48pm
Paddi
Can't be sure but I seem to remember posts on range rovers.net by people who did it.
Sunroofs are a fairly generic construction - I changed the outer seal on a Porsche sunroof and it took about 15 minutes. Just pull out the old one and push in the new.
Might be worth a call to a company like the famous Woolies Trim to see if they sell it by the metre?
http://www.woolies-trim.co.uk/ 2008 MY Java Black TDV8 HSE
Post #498445 Sat Jun 11 2016 2:47pm
LJRH
Thanks for the help!
Post #498453 Sat Jun 11 2016 4:11pm
Try LR023393 only Seal listed for Sunroof.
Post #498462 Sat Jun 11 2016 6:37pm
