Home > General (L494) > Stop/Start stopped - failing battery? |
Have you been using the climate control a lot recently? If you are cooling the interior to the lowest setting the load on the alternator might be enough to cause the system to lock out the Stop/Start. Mine has been doing similar (and I use stop/start all the time) for the last 10 days when the outside temperatures have been very high and I have been in town traffic. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Jun 09 2016 8:36am |
R444SPT Member Since: 20 Mar 2015 Location: Offroad somewhere Posts: 217 |
It's funny you say that I'm 3000 miles into my 2016 MY vehicle ( less than 3 months old, and after 6 weeks I have the same it now seems to work about 2 days every 3 weeks, when originally it was daily, I did think of sticking the ctek on it, and seeing if that made a difference. The lowest mileage it does is 10miles a time but generally the journeys are 40miles + on each occasion and that's twice a day minimum...
Thu Jun 09 2016 8:44am |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1671 |
It's been getting worse for a long time (many months), not just in the current weather. |
Thu Jun 09 2016 9:00am |
Peanut Member Since: 31 Jul 2012 Location: Leicestershire Posts: 110 |
Me too! This morning it is cooler and ss seems locked out.
Thu Jun 09 2016 9:17am |
Just put the CTEK on, and it's gone straight the 80% bulk charge phase,,and stayed there for quarter of hour before heading to the 80%-100% phase, which actually I thought it would probably go straight to, will leave it on for today,,and see what tomorrow brings when it gets used, a very rare day off for it... |
Thu Jun 09 2016 9:36am |
I have CTEKs on all of my toy cars, but wouldn't expect to need one on my daily car that does 18k miles a year! |
Thu Jun 09 2016 10:34am |
Indeed not, but something is potentially causing a drain to levels where it cuts out,,if it not high use of a/c cold engine etc... |
Thu Jun 09 2016 10:40am |
But where it used to work and now isn't suggests the battery is failing or just isn't up to the job. |
Thu Jun 09 2016 10:43am |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 |
My dashcam is set to switch off below 12v in park mode and appears to be shutting down all the time
Thu Jun 09 2016 10:45am |
When replacing your battery, put a higher capacity (amps) battery, or better make, in your car. The battery can still be the same size, or some larger ones can fit, but I find at present with this very hot weather and doing lots of local runs to the beach etc,p (even with overnight trickle charge) I'm getting warnings to turn off radio or TV/DVD soon as stationary or restart ignition. So yes with everything running, same in winter, you use more than alternator can recharge on short runs. John
Thu Jun 09 2016 12:42pm |
That's great but we shouldnt even be talking about replacing batteries on a car that is 3 months old (mine) or I'm guessing 9-12 months old for the SVR now. |
Thu Jun 09 2016 12:45pm |
Thats just terrible, I guess reducing the timer on the dashcam may work (4 / 8 hours instead of 48 hours running - ) of course it may be a small price depending on where you park the car... |
Thu Jun 09 2016 12:46pm |
JOCK55 Member Since: 01 Sep 2015 Location: INVERNESS Posts: 415 |
The start/stop has been stopped on my MY 2015 RRS more or less since I first had it. It has been back to the dealer twice now for investigation. The response is that my "driving style" is insufficient to keep the batteries fully charged! I asked what would be "sufficient" and the response was around 40 miles per day motorway (non-stop) driving or 60+ miles per day mixed urban driving to keep the batteries at full performance!!!! This prompted several questions, not least of which was the use of the plural when referring to batteries. I was told that the L494 has 2 batteries. 1 located under the spare wheel and the other on the off-side rear of the boot. Apparently, the alternator now has to keep 2 batteries fed with power but has not increased in capacity since this modification. The stop/start requires a high voltage level to maintain operation and is the first thing that gets switched off by the power management system when voltages drop. I continue to live without a functioning stop/start system as I do not generate anything like the recommended daily mileage to keep the system operable.
Thu Jun 09 2016 4:03pm |
& following 7/8 hours on the CTEK today, the stop start now works as JLR intended.
Thu Jun 09 2016 6:13pm |
