Home > Maintenance & Modifications > Couple of easy Questions. |
Jock 77 Member Since: 13 Apr 2012 Location: Falkirk Posts: 187 |
Hi Lads hope you don't mind a couple of easy questions.
Wed Jun 08 2016 7:48pm |
Hi Andy thanks for the reply, I am in between my first and second cambelt change but noticed today that the Fanbelt is quite badly cracked so thought I would just change it out.
Wed Jun 08 2016 9:28pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
1) Yes, but it's a PITA 2) I use stainless plates. Should have said, I could have given you a pair away with you 3) I always use OEM filters when servicing. Around half the price of genuine parts, but all made by the same manufacturer Saves you paying the Land Rover tax, if you will |
Wed Jun 08 2016 9:30pm |
Thanks for the reply Mikey.
Wed Jun 08 2016 9:43pm |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
Personally after reading about failed engines due to poor quality oil filters I would only use gen oil filters as for the rest your choice but don't use britpart fuel filters had a few problems with those before today.. 2008 G4 RRSport TDV8 current
Wed Jun 08 2016 10:13pm |
Mahle air + oil filters, Delhi fuel filter are OEM. Pollen filter is a pollen filter, so cheaper the better. And get a new sump plug too
Cheers Mikey
Wed Jun 08 2016 10:31pm |
Hi Camelrock
Thu Jun 16 2016 10:38am |
