Home > General > brake pads burning / intense heat |
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 |
Sounds like calliper sticking |
Tue Jun 07 2016 8:49am |
mac01642 Member Since: 31 May 2016 Location: north east Posts: 20 |
thanks for the reply, is there any maintenance you can do on the existing callipers ? or is the next option is to change the front callipers ? |
Tue Jun 07 2016 9:09am |
Not sure if there is a service kit for the calipers but I'm sure someone with more knowledge will be along soon |
Tue Jun 07 2016 9:19am |
dalmat Member Since: 09 Sep 2015 Location: Split Posts: 36 |
From my experience with Jeep GC and similar case few years ago (front left caliper seized) I think that you should replace cylinders. Too much heat totally destroyed inner part of cylinder and material changed colour so the safest way for me was to replace all parts under such heat. You are probably on the same path |
Wed Jun 08 2016 7:36am |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
I would suggest the first thing to check is the sliders quite common for them to seize up in the carrier. If there ok and it is the calipar it's worth pricing an exchange unit rather than changing Pistons, seals etc 2008 G4 RRSport TDV8 current
Wed Jun 08 2016 8:18am |
