Home > Faults & Fixes > Suspension fault
Plazmapete
Suspension fault
About a month ago While driving I've had a amber suspension warning light come on. Stopped at the services and turned engine off. Then started again. All was fine for 20 minutes then it came back on again. It's been fine since.[/i]
Post #497896 Sun Jun 05 2016 3:33pm
ShooterNeil
England 2007 Range Rover Sport TDV8 HSE Java Black
Battery may be on its way out
Post #497910 Sun Jun 05 2016 6:05pm
Plazmapete
Thanks for the reply. I have read about battery could cause these problems. But kwik fit tested battery with a bosch tester and it was fine. If the faults continue May bit the bullet and buy a new battery.
Post #497911 Sun Jun 05 2016 6:11pm
Tyrefitter
Kwik-Fit Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #497912 Sun Jun 05 2016 6:28pm
Plazmapete
Funny.
I had my aircon re-gased. While I was there I asked them to check the battery. Are these range rover sports that fussy about a battery? It starts first time every day.
Post #497914 Sun Jun 05 2016 6:59pm
PEACHY
Range Rover Sports are fussy about anything & everything - worse than a woman IMO
I apologise in advance if I upset any female members or visitors to the forum Rolling Eyes Rolling with laughter Rolling with laughter 16MY Estoril Blue SVR.............
Post #497917 Sun Jun 05 2016 8:04pm
PEACHY
It seems you may have a few minor issues judging from your first few posts Crying or Very sad
Try getting in touch with Bodsy ( site sponsor ) he lives your way. Let him know your issues / concerns & I'm sure he will offer the best advice - the guy is a legend Bow down Thumbs Up 16MY Estoril Blue SVR.............
Post #497919 Sun Jun 05 2016 8:16pm
Johnski
One of the problems that many of our members don't realise is that although the alternator will put a charge back in the correct charge to battery, if you are doing consistant short runs of a few miles, and extra things running on Car, then the battery will get lower. I find by leaving it on trickle charge a couple of times a week keeps my battery in good nick, plus a few 500 mile round trips help. But a cold morning with Hester's seats etc on will soon give a flat one if you don't do a few runs to keep it topped up, and yes, some will say that's a load of bull, but many a battery that's been "flat" has worked fine for months after a proper charge.
I also don't believe that the on/off facility, on newer models when. Car turns off at lights/stationary etc is anyway to treat a battery.
When changing, get a good make with the correct current(amps). The RRS to have regular faults caused by the battery, but quite often it's purely the charge or condition. There is a hell of a lot of electrics on all our cars. Wink John
Post #497920 Sun Jun 05 2016 8:19pm
Plazmapete
Thanks for all the replies. Will look into it
Post #497928 Sun Jun 05 2016 8:51pm
Plazmapete wrote:
Funny.
They are fussy about their electrical supply, yes. The battery can be OK to start but not be good enough to run the car thereafter. It is often the sign that the alternator is on its last legs.
The problem with checking the battery is that it really needs to rest for 24 hours after engine off to disperse any surface charge on the plates. It might show 12V when you switch off but the next day a check will show much less.
When the suspension lowered, did it go down to its bump stops? That might suggest a corrupted height calibration. This might be related to the battery / alternator too. Really needs the error codes reading to get go bottom of it. 2012 SDV6 - it's missing a couple of cylinders
Post #497930 Sun Jun 05 2016 8:57pm
Plazmapete
Thanks. Will get it booked into garage.
Post #497931 Sun Jun 05 2016 9:06pm
Plazmapete
Using the on-board screen it's 12volts at rest and 14volts at around 1500rpm.
Post #497981 Mon Jun 06 2016 12:20pm
Down&Dirty
Can't rely on on board system but at rest it should be around 12.4v needs a proper meter putting on it. Thumbs Up Currently MY16 Disco 4 Mr. Green
Ex RRS MY13
Ex Discovery 3 MY08
Post #497982 Mon Jun 06 2016 12:37pm
12V isn't that great - it's less than 50% charged. 2012 SDV6 - it's missing a couple of cylinders
Post #498027 Mon Jun 06 2016 7:48pm
