![]() | Home > Maintenance & Modifications > Fitting xenon headlights? |
Driller Member Since: 18 Aug 2006 Location: Perth Posts: 80 ![]() ![]() ![]() |
Just received my new RRS. Being the impatient type, rang around Australia till i found one with the options i wanted (and a few others i might add) but missed out on the xenon headlights. Anyone out there know if it's possible to fit the xenon headlights, not the adaptive, after delivery? I can't imagine it would be too much of a problem, just curious if they required heavier duty wiring or something? |
You may be able to do it, but the wiring harness will doubtless need to change. Xenons require a higher voltage to work.... you might alternatively consider higher rated halogens. I went through that circus with Mrs Shmoogle's FL a while ago... |
Thanks cliff,
Hmm... I'm sure when I was looking into it for the FL it wasn't as simple as just swapping the bulbs. I suppose it may well be different for different cars. Let us know how it pans out for the RRS, driller... looks like a useful bit of info will come to the surface |
Will there be any issue with the heat from the new bulbs? 2005 Zambezi TDV6 - Gone but not forgotten
Cliff H Member Since: 03 Dec 2005 Location: uk Posts: 3233 ![]() ![]() |
No you can't just change the bulbs, I am talking about changing the whole lamps |
Yes, what he said |
I understand that all xenon headlights must have the headlamp spray jets installed also... . Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Yes indeed, was looking at changing out the whole assembly. Not really keen on aftermarket rubbish and bolt ons. Cliff, how nuch did you pay for your D3 units. Just got a quote here in oz for an absolutely ridiculous amount of money, $5000.00 each! |
Compuway Member Since: 01 Apr 2006 Location: Perth - Western Australia Posts: 57 ![]() ![]() ![]() |
Heh Driller you have a PM 2006 RRS TDV6, Java/Alpaca, Dynamic Response Pack, Tow Pack, Head and Tail light protectors, 20" Stormers, Roof Rails, S/C Grill and Side Vents, Tasmods. AutoLogic mod.
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2584 ![]() ![]() ![]() |
Isn't that more of a legal requirement rather than safety or functional? L319 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB |
Singletrack Member Since: 07 May 2006 Location: Belgium - Lasne Posts: 330 ![]() ![]() ![]() |
You are correct - it is a legal requirement in Europe to have both headlight washers and dynamic height adjustments... Illegale Xenon-Nachrüstung ist gefährlich und verboten 2006 Range Rover Sport TDV6 HSE, Java/Ebony/Cherry, Privacy, Sunroof, PTI, Premium Sound, SatNav, Cold Climate, Tow kit, CarStyle coded grill and vents, Tasmods, Stormers, JE Exhaust, Autobiography badge |
Nicht auf das Gras gehen!! |
Sorry to be a bore but getting back on topic quickly, i have managed to find the information i require and will be under taking the op as soon as i get back on land. For those of you interested, see my thread in technical, part no's, and it will give more info. I'll let you get back to your banter now, boobies anyone?! |
