Home > Technical > Brake lights
LJRH
Brake lights
Slight problem.
When my headlights are on my brake lights don't work.. The 3rd light stays on and the other two do not get brighter as they should do when the pedal is depressed. When the headlights are off, they work.
There are no blown fuses.
Any ideas?
Many thanks
Post #497798 Sat Jun 04 2016 9:51am
Sounds like a bad earth at the rear of the car.
I would have expected move faults with the rear lights though , like no reversing lights.
Do you have led rear lights ? Aftermarket ? Check they are fitted well if you do
Post #497821 Sat Jun 04 2016 12:59pm
Saeedasghar
2006 Range Rover Sport TDV6 HSE Java Black
http://www.rrsport.co.uk/forum/topic43279.html
Similar issue with headlights and brake lights hope this helps
Post #497822 Sat Jun 04 2016 1:00pm
LJRH
All sorted.
I guess they call it Halfrauds for a reason huh? They had given me replacement bulbs with the wrong connectors. Typical!
Post #497823 Sat Jun 04 2016 1:02pm
Lost for Words
It is advisable to avoid Halfords bulbs altogether, as cheap brake bulbs can wreak havoc. Thumbs Up Visiting from DISCO3.CO.UK
Post #497843 Sat Jun 04 2016 4:34pm
Camelrock
Fitted LED bulbs in mine never had a problem in nearly 7 years now 4 in my D3 swapped them into the sport. So much brighter side and brake and to my mind match the high level b/light. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #497846 Sat Jun 04 2016 4:52pm
