![]() | Home > In Car Electronics > LED Trailer Lights |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
You can purchase gold resistors off ebay.
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
Or should I be using a Universal Bypass Relay like below?
You don't need a bypass relay.
Jeep948 Member Since: 17 Jul 2015 Location: Scottish Borders Posts: 8 ![]() ![]() |
Further to the information on this thread I have the 'IN-LINE CANBUS LOAD RESISTORS' fitted to my trailer and still the indicators pulse, has anyone any other suggestions as to another fix? Thanks in Advance |
jaxx Member Since: 13 Jun 2011 Location: Pyrenees Posts: 62 ![]() ![]() ![]() |
I was stopped a few weeks ago by Spanish police in the Pyrenees late at night due to my incandescent trailer lights being out etc. forced me to a nearby garage where I could get bulbs. I just managed to get 1 that worked, after they left I bolted home half frozen. I bought a set of LEDs from Amazon and had a real nightmare to get them to work etc, however, i found that the wiring on the lamps did not match the correct positions on the plug so i set about going through all the possibilities i could think of. I even bought a cheap digital Plug/socket tester and this really is a must for LEDs, anyways on the JLR schematics nothing worked for me. where the brown and black from the Lamps should go to pins 7 and 5 for the tail/running lights i found this should have been the blue wires normally for the Fog etc. originally i have 7 pin socket on the trailer to 13 pins on the car etc so i rewired this and it worked with the blue wires connected to pin 4 and black and brown connected to pin 3 normally the ground etc. after this i installed a 13 pin plug on the trailer end and this gave me reversing lights as well via pin 8. Could run another wire through pin 2 and get the Fog lamps going, however, i don't see the need.
Do find that:
No flicker at all
Rear Parking Sensors working fine, however, I Guess they should be disabled, no worry for me though.
