![]() | Home > Maintenance & Modifications > 6 Pot Brembo Callipers |
Maybe brembo's don't have a place for a wear sensor. |
Sensor fits to N/S Inner Brake Pad, if memory serves me correctly. Sensor does not actually fit to the Caliper.
tonywolf Member Since: 14 Sep 2015 Location: Devon Posts: 97 ![]() ![]() ![]() |
Thanks Col, I did look at that , but dismissed it :blue: Does it matter which part of the N/S brake pad it goes to i.e. top or bottom? And I presume it will go onto the inner pad? Best Regards
Is can be seen here on the right
oh right that makes sense. Thanks all |
N/S Caliper, Inner Pad to the Bottom there is a there is a Cut Out in the Caliper where the wire feeds through. Cheers Col |
