Home > Maintenance & Modifications > Front indicator bulb change
HS66
2005 Range Rover Sport TDV6 SE Bonatti Grey
The bulb has gone on my front O/S indicator, had a quick look last night but doesn't look very easy to access, is there a simple way of changing it?.
Post #496576 Fri May 20 2016 7:40am
1. Remove grille
2. Remove headlight. Use a loop of strong cord to pull up the two retaining catches. Unplug the wiring connector making sure you don't drop the light!
3. Access the bulb. From memory you need to slide the retaining catch out of the way to access the cover.
4. Reverse to refit. 2012 SDV6 - it's missing a couple of cylinders
Post #496582 Fri May 20 2016 8:26am
