![]() | Home > Technical > Correct Width & Offset on 22" Wheels |
Singletrack Member Since: 07 May 2006 Location: Belgium - Lasne Posts: 330 ![]() ![]() ![]() |
This is not factory data but from one of the UK wheel suppliers: PCD: 5 x 120, Offset: 30 to 50, Bore: 72.6
mikerugg Member Since: 10 Sep 2005 Location: Newport Beach, CA Posts: 14 ![]() |
Thank you singletrack, that is exactly what I wanted- a reference point for the wheel guys out here.
Black/Black w/ Every Option |
What is that ?? RRS TDV6 Gone but still around
Giovanna Caracas. 24"s in the picture, but they interfere with the automatic lowering at speed, which sounds no bueno, so 22"s for me. 2005 Supercharged Range Rover Sport
Is the window tinting Photoshopped in? Doesn't look right... |
It is a bit dark |
Kaine Member Since: 26 May 2006 Location: Hills of Shropshire Posts: 8902 ![]() ![]() |
yep - looks photo chopped - wheels maybe aswel |
You can see someone taking the pic RRS TDV6 Gone but still around
and now you cant ![]()
not bad at all mate |
Clever, Kaine! |
Kaine, did you just use the healing brush feature in photoshop, using the alt key to sample the source you wanted? 2005 Supercharged Range Rover Sport
Thats good, Kaine. |
