![]() | Home > Faults & Fixes > help range rover sport 08 unable to unlock with key fobs |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4449 ![]() ![]() ![]() |
Emergency key lock in the passenger front door |
kev701 Member Since: 01 Feb 2016 Location: Yorkshire Posts: 2 ![]() ![]() ![]() |
thanks i have gained entry and nothing worked when key was turned in ignition , i opened the bonnet and just touched the box that the battery was in and the alarm system started going off turned alarm off with car key and engine started ok... so not sure what is going off |
tom0311 Member Since: 01 Apr 2016 Location: witney Posts: 240 ![]() ![]() ![]() |
Get a multimeter and check what the battery voltage is? See if it holds charge ok? Probs first thing I would do. |
