Home > Maintenance & Modifications > Gearbox Mega Flush |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
A megaflush only needs a couple of Pipes disconnected in order to be carried out,,, a torque converter would certainly need a few items removed I order to be replaced. If you were sure you had a faulty Tc a flush would not make any difference. 2010 RRS, TDV8
Fri May 13 2016 7:53am |
tom0311 Member Since: 01 Apr 2016 Location: witney Posts: 240 |
On the subject of mega flushes, how do you know when you need one? When the transmission isn't smooth anymore? |
Fri May 13 2016 9:18am |
Manufacturers recommend a flush at 75k miles I think, best having it done before you notice any problems 2010 RRS, TDV8
Fri May 13 2016 9:36am |
Cool. It was done around that time. On 90,000 now, might get it done at 100,000 then. I hear the 75,000 interval is very optimistic. |
Fri May 13 2016 10:10am |
caperbility Member Since: 14 Jan 2010 Location: landscaping the world Posts: 221 |
I had mine done at 93k at the above garage
Sat May 14 2016 6:12am |
Langdaleend Member Since: 10 Jan 2016 Location: Yorkshire Posts: 2 |
Thanks for the replies.
Sat May 14 2016 7:41am |
