Home > Wheels & Tyres > Help - Black 'spare' alloy rim from RRS
cotefarmboy
I'm after a very cheap 19" rim to use as a spare (no tyre required) instead of the skinny space-saver I have now.
Does anyone know why the 19" 6 spoke HSE rims that are painted black and were supplied as spares on the older RRS have a '50 mph' warning label attached? Are the rims a lower load rating than the silver equivalent? The whole point of me sourcing a full size spare is so I can continue to drive at normal speeds after changing it so don't want to buy one of these if it won't do the job. Andy
D4 SDV6 HSE
Post #495573 Tue May 10 2016 3:13pm
muddywheels
Milk Float Man
They have the 50mph because most RRS are fitted with 20" so wouldn't be a match and classed as emergency wheel
Even if you had 19" they may be different tyre or alloy model so they cover their backs
If you want to drive normal speed without issues you need 5 matching alloys and tyres I think Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #495574 Tue May 10 2016 3:17pm
cotefarmboy
Thanks, I would be fitting a tyre that matches the rest of mine (it's a D4 on 19's) so the wheel itself was the concern, couldn't really see what difference it would make but now I see that mixed with 20's on a RRS it would be a different prospect Thumbs Up
I can pick up one of these old black rims for peanuts compared to £150+ for a matching alloy so it's a no-brainer really as a spare. Andy
D4 SDV6 HSE
Post #495575 Tue May 10 2016 3:21pm
muddywheels
Milk Float Man
There are issues using rrs alloys on D4 due to different weight rating so just check
Also a lot of owners had their spares stolen which then appear cheap on ebay Embarassed Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #495576 Tue May 10 2016 3:32pm
The black spare is a slightly narrower rim than the normal 19in road rims. You can fit a full size tyre, of course, and it works just fine. My tyre guy tells me that with the full size tyre fitted you can ignore the warning sticker; from a physical safety issue he's probably right, however I'm sure an insurance company would use it against you in a claim.
I've moved to a full 19in alloy as my spare now. I've got three other 19in alloys in the garage - I'd intended to have a set Duratracs and a set of ATRs but I'll need to find another full size alloy now... 2012 SDV6 - it's missing a couple of cylinders
Post #495606 Tue May 10 2016 9:39pm
