![]() | Home > Wheels & Tyres > Summer wheels back on and I was thinking.... |
These I like:
KennyR Member Since: 28 Jul 2015 Location: Gourock Posts: 178 ![]() ![]() |
I like those Rob, do they fit the sport? ____________________
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
The L322 Stud Pattern is the same however I think you will need the L322 Wheel Nuts as well as they had a different shoulder diameter something like 20mm on L332 and 22mm on Sport although it may be year dependant.
Anywhere we can check that? Topix? Main dealer? Visitor from fullfatrr.com * GONE. 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8 * GONE: 2011 4.4 TDV8 Full Fat. Amazing piece of kit. * Current. 1974 Lightweight 2.25L petrol. Old skool * GONE. Freelander GS TD4 Manual MY2013. Orkney Grey with privacy, cold and clearview packs, armrests (a must!) and a spoiler. * GONE. Range Rover Classic '93 200Tdi Factory fit * 1949 80" in family since 1975 |
Just had a quick look at parts list, it looks like they changed to the later ones part way between the 2002-2009 year L322 car. So if the wheels came off a 2010 on car they should be O.K. any earlier you might need to check the wheel to be sure. They changed at VIN 6A00001 and again at 8A265241 which really doesn't help if you only have the wheels.
