Home > General > Original Daytime Running Lamps
muddywheels
Milk Float Man
From what Col posted as I suspected it's dipped headlights only unless you fit drls and activate them Sad
You beat me to it Laughing Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #476166 Mon Oct 12 2015 7:12pm
fdhadi
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
The lights on our 2011 RRS are set to the Scandinavian setting. So annoying Big Cry . I tend to drive during the day with the fairy (side) lights on. If I wanted the dipped lights to stay on I could just turn to the auto setting.
Frank
Post #476193 Mon Oct 12 2015 9:26pm
Hi
Easy enough to de-activate, would think any Independent with Blackbox, Autologic or the like of should be able to do it for you if you wanted.
Post #476201 Mon Oct 12 2015 10:08pm
fdhadi
Thanks for that Col. I'll get it sorted on its next service.
Regards
Frank
Post #476212 Tue Oct 13 2015 7:31am
LG8340
England 2013 Range Rover Sport SDV6 HSE Lux Santorini Black
Hi Col
Are you happy with your tailgate open/close?
What's the best way to have sidelights on with ignition? Can it be done by programming?
Kr
Michael RRS (MY13) Santorini Black SDV6 HSE luxuary
Gone: Evoque, Freelander 2, Mercedes 320 CLK, Porsche 911's
Post #494728 Fri Apr 29 2016 11:01am
Hi Michael,
Am very impressed with the Open/Closure mod, Nice one Carl Thumbs Up
As regards to Sidelights on with Ignition read my quote below it is all you can activate through the CCF files
Col wrote:
Hi
Have gone into the CCF files and there are three options listed on my car a MY13 A/B 5.0L S/C.
1. DRL Standard
2. Scandinavian
3. Canadian
I activated Standard and all that did was give me two Fault Codes B124A-15 and B124B-15 which are Left and Right Daytime Running Light open Circuit but no working DRL's so it may be when you have either DRL lamp kit VPLSV0064 or 65 fitted you may have to activate this but that is purely a guess. By the way those kit's are over £400.00
De-activated that and then activated Canadian and what that did was nothing with ignition on and Engine Running, however when you engage Drive and let the Park Brake Off it Switched Front and Rear Side Lights and Dipped Headlights On, as soon as you apply P/B and take it out of Drive It switches them Back Off.
Again De-activated that and Activated Scandinavian and what that did was as soon as you Start Engine it Switched on Front and Rear Sidelights and Dipped Headlights. (Muddy was correct there).
There is no facility that I could find to just activate the Front Fairy Lights on there own as DRL's.
I hope that all makes some kind of sense.
Post #494731 Fri Apr 29 2016 12:16pm
