![]() | Home > Technical > Battery |
SONYBOY Member Since: 22 Dec 2010 Location: East Of England Posts: 70 ![]() ![]() ![]() |
hi all, im haveing problems with batteryon my 07 RRS..i went to buy a new battery but was told no need, got to drive for at least 18 miles to charge the battery up,,,what the ek..!!! he then told me to buy a solar power pack to trickle charge the battery.... what are your views please,?? 2007 COOLRRS |
You'd have to drive all day at good speed to charge it. A solar trickle charger isn't a bad idea, but to really charge it you need to get a proper charger on it. A smart charger like a CTEK is ideal.
If you aren't using it very much and have mains power near the car, buy a CTEK 5 charger. £60 on ebay |
hi guys thanks for your replys |
If it's like mine with the original " wet cell " battery, make sure it has plenty of distilled water in it, but as the other guys have mentioned, get a ctek charger and give it a boost once a week otherwise it will eventually let you down 2010 RRS, TDV8
hi all, got it sorted now, the solar panel went back as it discharged my battery, !!!.... and checked the cells in the battery, 2 were a mucky colour and done for... so new battery it was then... SORTED at last....drive 18 miles my A*** 2007 COOLRRS |
You were obviously talking to some kind of monkey about your battery.....! You'd be hard pressed to find any better advice than on here |
