Home > Technical > Auto Gearbox Faults |
Tim Hoang Member Since: 29 Jan 2008 Location: London Posts: 77 |
Within two weeks, several gearbox faults happened but after stop and restart the engine its all back to normal. plug in the Hawkeye Diagnostic there are 2 fault code:
Thu May 09 2013 2:48pm |
Tim,
Thu May 09 2013 4:13pm |
Definitely no other symptom, Bodsy. 2005 RRS TDV6 HSE Java Black
Thu May 09 2013 8:53pm |
i wonder if the mechatronic control in the gearbox is sticking (it's the bit that controls where the fluid goes for gear changes etc.)
Fri May 10 2013 10:47am |
Thanks Bodsy. I'll go down to Dartford transmission to have it checked. 2005 RRS TDV6 HSE Java Black
Fri May 10 2013 11:17am |
Bodsys Brake Bible
Fri May 10 2013 11:42am |
It's been confirmed that the clutch(s) is 'thin' and need to be changed. Cost approx. 2k +VAT and take a week to be done.
Wed May 15 2013 10:02am |
Bad news sorry to hear that. Maybe worth getting a second opinion? Perhaps give these chaps a ring - ask to speak to Jason.
Wed May 15 2013 10:43am |
tim, Bristol Transmissions (a bit of a trek I know) would provide a recon torque converter for approx £450 plus fitting and oil. They have a very good reputation.
Fri May 17 2013 9:11am |
But they say its the clutch that make the slip in 5th and 6th gear. With that figure they'll change both clutch and TC. Don't know much about auto gearbox. What you think. 2005 RRS TDV6 HSE Java Black
Fri May 17 2013 9:50am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
There are several clutches in the gearbox but the one they're most likely talking about is the torque converter lock-up clutch.
The other three clutches (and two brakes) are used to create the gear ratios. These are obviously within the gearbox. If it's slipping in only 5th and 6th then it could be clutch B which is used to create 5th gear (although it's also used in 3rd and reverse). Anyway, here's the Disco3 manual for the automatic gearbox: http://www.rrsport.co.uk/gallery/albums/us...ration.pdf 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Fri May 17 2013 1:54pm |
Farax100 Member Since: 18 Apr 2016 Location: London Posts: 12 |
Can a software update help? I forgot to add this to my message. |
Tue Apr 19 2016 12:40am |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Don't think so... Visiting from DISCO3.CO.UK
Tue Apr 19 2016 8:38am |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 |
I had all this and more with mine, it can't be fixed, the autobox needs a complete rebuild, mine cost £1800 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater ))) |
Tue Apr 19 2016 9:36am |
