Home > General > Air suspension advice |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
What is the symptom you're trying to diagnose? "Playing tricks" doesn't give us much to work with... 2012 SDV6 - it's missing a couple of cylinders
Sun Apr 17 2016 7:15pm |
Bullnogger Member Since: 29 Mar 2016 Location: Stoke on trent Posts: 81 |
When parked up at night passenger side front is first leg to start dropping then driver side then rear within 4 hours front is down to access height I've soap tested everything today not a sign of anything leaking it's always front passenger side that starts to drop first I park on a drive that has a small fall to one side so vehicle is leaning towards front passenger wheel I would of thought driver side would come down to try and level vehicle up I've reversed in tonight so it's back driver side wheel at lowest point just been out to check after being parked for 2 hours not budged all wheels same height will check in morning 3 am before I go work see how she's sitting thank you for your reply |
Sun Apr 17 2016 7:46pm |
First thing to do after your test tonight, is to remove the EAS fuse when you next park up in the normal way. If it still drops then it's likely a leak. If it doesn't then that suggests a height sensor possibly. If you sit the car on a level bit of tarmac and select access height, does it go down? Does the 4x4 info screen show any red bars above a wheel?
Sun Apr 17 2016 9:40pm |
Thank you for your advice looked at it 3.10 am hasn't moved an inch will try what you have said this weekend as I work away
Mon Apr 18 2016 2:50am |
