Home > General > Seats, mirrors and windows
Graz
So the electric seats have stopped working, along with the mirrors (they still fold in though) and two of the electric Windows. I've checked all the fuses as per the chart and they seem fine. Does anyone have any other ideas before I take it in to the garage to get plugged in to the diagnostic unit?
Post #493655 Sat Apr 16 2016 5:57pm
beads
United Kingdom 2007 Range Rover Sport TDV6 SE Siberian Silver
im in the same boat as you with the seats also my mirrors haven't folded in since purchase, and the seats only stopped working after i had timing belt etc done ;/ look forward to hearing any updates.
Post #493762 Mon Apr 18 2016 7:45am
Socast
Hi Beads,
You know the mirrors don't fold automatically don't you ?
You need to centre (rather than it being twisted to the left or right to adjust the appropriate mirror) the adjuster nob and then push it down. This will either fold them in or out.
Post #493765 Mon Apr 18 2016 9:47am
beads
hehe yeh i knew that mate Wink
Post #493766 Mon Apr 18 2016 10:04am
alpaca
United States 2006 Range Rover Sport 4.4 V8 HSE Zambezi Silver
I had mirror and window issue on passenger side - but fuse kept blowing - bad mirror motor. If fuses are ok - a few other places to look.
Check wiring connectors under passenger front seat (lhd) ...if seat is moved too far forward and cable snags these can come loose.
Did floor get wet from sunroof drain clog ? Could have wiring issues in that case under right sill/carpet
Else you might have bad control unit (under drivers seat) - check all connections first - but these units have been known to require replacement. Good indie should be able
To quickly diagnose based on what is not working and what is...
Post #493795 Mon Apr 18 2016 1:42pm
Graz
Thanks alpaca
Post #493855 Mon Apr 18 2016 7:20pm
