Home > General > Vibration "issues" ! HELP / SUGGESTIONS PLEASE ! |
Jeez, that has had some money spent on it. Sounds like the dealer doing all that work is chasing the issue without success. After you have been out on a run and this problem has occured, have you had a feel of the back wheels to see if they are hot? If so, then it is a common problem. Your electronic parking brake is sticking on. If it isn't that, then i'm sure Disco Mikey will be along very soon to give you a few more ideas what it might be. |
Mon Apr 11 2016 6:24am |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 |
Hi ,as above, i had this and it was the EPB sticking 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Mon Apr 11 2016 7:43am |
Lezzo Member Since: 20 Dec 2013 Location: Rotherham Posts: 26 |
Thanks for your replies gents ! I will speak with the guys who have been working on it. Although I would have thought that the EPB issue would be felt from any speed ? Regards Lezzo |
Mon Apr 11 2016 8:08am |
ozzievechi Member Since: 14 Mar 2016 Location: london Posts: 55 |
mine did same, needed balancing and the front break discs changing and resolved the problem. As they did both at same time cant say if it was one or other or combo of both |
Mon Apr 11 2016 8:31am |
Hi, never really noticed round town as 40mph where i live is impossible, when we visited our caravan down the motorway it happened all the time. Had it backed off and adjusted and now all fine. Basically it got hotter and expanded more with higher speed 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Mon Apr 11 2016 10:08am |
seem to recall a celebrated contributor to this forum (Simple Simon?) who had an incurable vibration after an engine change.
Mon Apr 11 2016 11:57am |
Hi peeps ! Many many thanks for your replies ! The issue is still unresolved on said car but I have ended up swapping it for a different newer Rangey anyway ! The end result will be relayed to me as and when it finally is resolved ! |
Mon Apr 11 2016 3:05pm |
