![]() | Home > Australia & New Zealand > TOWING ISSUES |
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 ![]() ![]() ![]() |
I have some minor towing issues with my RRS s/c. Not that it won't tow my 1500kg poptop but not nearly as well as my other SUV a Ford Territory Turbo. |
I have some pitching which I put down to the air suspension and its suppleness but it is not really an issue.
Arctic Frost Aspen Interior |
Thanks for the reply Garry.
My ball weight is 200kg as everything including the water tank and batteries are forward of the axle.
It comes in at about 1.2 tonnes and the ball weight is only about 80kg but the amount of pitch is still about the same as the camper with 200kg ball weight - so the suspension seems to cope the same irrespective of the weight. I am not sure what you can do - if the airbags are Ok which they obviously are, the only other thing to look at are the shocks - if they are old their control of the pitch will be reduced so maybe a new heavier grade might be the go - it depends on how much you tow and whether you can live with what you have now but if you upgrade what will the ride be like when not towing - I would have thought it would be Ok. I have LLAMS so drive and tow on the road at 20mm below onroad height. On the gravel I normally go to onroad height and when offroad, the height will be selected as needed. I would not be towing at offroad height for any distance as it will not be good for your CVs and other suspension components - so stay at onroad height and adjust when needed. Cheers Garry 07MY RRS TDV6 Arctic Frost Aspen Interior |
e again thanks for the information. I will have to get my tow ball weight measured but as the Territory tows it without any problems I don't think that will be the answer. Shocks maybe the go. So you have used an IDD/ tool to alter your suspension settings. How do you think that worked out? I have thought it be be great to have a "freeway" height halfway between access and normal. |
Yes check those shocks.
whippetman Member Since: 12 Jun 2010 Location: on the level Posts: 502 ![]() ![]() ![]() |
Hi Mw
Thanks for the info guys. I had already got the info on the Llams just before you replied Garry.
No - LLAMS will not help with your towing - likewise aftermarket airbags if they exist will not do much.
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 872 ![]() ![]() |
I'd like to tow my trailer but in True Range Rover style they do not provide the tow bar Tongue ?? Of course this can be purchased as an extra for $280.00 M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Why would you buy it from LR and not a specialist tow bar place for about $45 and up.
Yes you are correct why indeed , however it should be supplied. Issue for me is the right length , I have one that was supplied with my Touareg but it seems to short. Thanks for the links I'll try the long and hope that will be money well spent. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Your local towing/trailer/caravan place will be able to order exactly what you need. 07MY RRS TDV6
Tried both the local Hayman Reese places in Wollongong and basically they did't have a clue , they can advise the part that goes with the Hayman bar but the RRS bar is fitted at factory and although the tongue fitting is standard the other dimensions may differ. So I'll take some measurements and then see how I go with the ones on the WEB. Just measured the one I have and am confident the cheaper one will give me the extra distance and for $45 I'll take the risk. Thanks for the help . if you see a Grey RRS SDV 8 in Canberra Friday it will be me. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
