Home > General > Park mode - rotary gear selector |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Can someone please check their 8 speed rotary dials retract if switched off in neutral
Thu Apr 07 2016 8:24pm |
Mine used to retract when the ignition was switched off, no matter what gear i was in. Found out by accident once. It also defaults to P. |
Thu Apr 07 2016 8:48pm |
Mine definitely defaults to park when ignition is switched off and retracts down no matter what gear you are in Rob. Sounds like something is amiss with yours. By all means try the operation of mine on Sunday to see what it should do if you haven't sorted it by then 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Thu Apr 07 2016 8:53pm |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2793 |
Im a little confused - I lower mine whilst in N then sometimes forget & switch off via the button. The Sport then alerts me the vehicle is not in Park & I have to turn the dial to P which then cancels all alerts & lowers the dial. 16MY Estoril Blue SVR.............
Thu Apr 07 2016 9:00pm |
I used to lower mine while on approach to my garage. I never did adjust the height while stationary. I was told by my dealer, it is better for the suspension components to do it while coasting. |
Thu Apr 07 2016 9:07pm |
As per lrtopix
Thu Apr 07 2016 9:14pm |
Perfect, thanks Peachy! That's what its doing so looks like I got myself confused. I can rest easy Visitor from fullfatrr.com * GONE. 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8 * GONE: 2011 4.4 TDV8 Full Fat. Amazing piece of kit. * Current. 1974 Lightweight 2.25L petrol. Old skool * GONE. Freelander GS TD4 Manual MY2013. Orkney Grey with privacy, cold and clearview packs, armrests (a must!) and a spoiler. * GONE. Range Rover Classic '93 200Tdi Factory fit * 1949 80" in family since 1975 |
Fri Apr 08 2016 6:31am |
Yep, that's what its doing so glad its normal Chris - yes, let's check yours out on Sunday before you get it mucky Visitor from fullfatrr.com * GONE. 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8 * GONE: 2011 4.4 TDV8 Full Fat. Amazing piece of kit. * Current. 1974 Lightweight 2.25L petrol. Old skool * GONE. Freelander GS TD4 Manual MY2013. Orkney Grey with privacy, cold and clearview packs, armrests (a must!) and a spoiler. * GONE. Range Rover Classic '93 200Tdi Factory fit * 1949 80" in family since 1975 |
Fri Apr 08 2016 6:34am |
