![]() | Home > Technical > auto side step switch help please |
| R444SPT Member Since: 20 Mar 2015 Location: Offroad somewhere Posts: 217
It does both, but you have to push it in a set sequence ie within 5 seconds of the ignition going on, or with the ignition off. - There should be a supplement that came with the car with the full instructions on. In their it also suggests suing it for the Roof Rack loading. All of that said, there is then other behaviours which cause it to be overridden so be careful with the remote in a pocket, unless you want the valet to fall off. |
