Home > General (L494) > problem with eta panel on navigation screen
pko
England 2013 Range Rover Sport SDV6 HSE Lux Orkney Grey
Hi all, a quick question about the small eta screen on the navigation panel. On my 2014 motor the little eta screen on the left was split into two, horizontally. The top section showed a distance and time countdown, and the lower one the ETA time, as shown on page 226 of the handbook. On my Dec 16 model the top half of this screen only shows the distance to go, but not the remaining time of travel left. In effect it is only repeating what is shown in the lower half. I've mentioned this to my dealer who agrees that there is something wrong, but only one other person has complained and he had a FFRR. Am I alone in this problem? Pushing the red spot emits a beep noise, but that's all. I believe on my earlier model pressing this enabled me to toggle between views
Post #492323 Thu Mar 31 2016 4:10pm
Autobiography
I don't have this issue sorry Sad a Same MY too.
Post #492325 Thu Mar 31 2016 4:23pm
Mark_N
It sounds like a bug in the navigation software and is likely to be model independent.
Check with the dealer that you have the most up to date version available and if you do, get them to report the problem to LR who will probably bin it as "Unable to recreate".
Mind you, the ETA is rather inaccurate because it does not take account of prevailing traffic conditions. I run a TomTom in parallel and the LR ETA always starts wildly different from the TomTom only to converge to it as the journey progresses. The TomTom time is uncannily accurate because it has full knowledge of the traffic en-route. Mark
SVR in Estoril Blue Thumbs Up
Post #492395 Fri Apr 01 2016 1:30am
pko
Thanks guys. I'll wait for the results from my dealer when he checks the ffrr & get it booked in. Remind me, what should happen when the red button is pressed?
kind regards
p
Post #492407 Fri Apr 01 2016 10:05am
philmw
United Kingdom 2012 Range Rover Sport Supercharged Sumatra Black
DO NOT PRESS THE RED BUTTON
Post #492422 Fri Apr 01 2016 1:17pm
Tim in Scotland
^ Rolling with laughter Rolling with laughter 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #492431 Fri Apr 01 2016 3:10pm
RRS Oli
I guess I wasn't going mad!!
I have this exact same issue on my MY16 SVR, don't normally use my satnav but was in the UK on the Easter weekend with my car and noticed this and thought it was odd.
Will be interested to know the outcome to point my dealer in the right direction to perform the minor fix on mine 2019 Urban Urus - May Delivery. Gone to the dark side...
2019 RRS SVR Velocity Blue Rejected!
2016 RRS SVR Estoril Blue
RRS1 2011 3.0 TDV6 Autobiography - SOLD
Post #492454 Fri Apr 01 2016 8:37pm
pko
hi rrs, it seems odd that we're the only two experiencing this. If my dealer gets back to me with a fix I'll let you know.
Post #492492 Sat Apr 02 2016 10:46am
udash
2013 Range Rover Sport SDV6 Autobiography Firenze Red
Same on mine, MY16, TOP box shows ETA and distance to travel, rather then time and distance as lower box shows ETA.
Post #492494 Sat Apr 02 2016 11:15am
DrFox1969
Australia
Same issue on my 2 week old car.
Be interested to see the outcome of your discussions. 2016 Range Rover Sport SDV8 HSE Dynamic (Indus Silver/Santorini Black Pano Roof, Ebony/Cirrus leather, custom grey Style 508 alloys)
Post #492559 Sun Apr 03 2016 2:45am
jpegnall
Have noticed it on mine too.
Post #492584 Sun Apr 03 2016 9:48am
scrumps
I've been having a play with my month old AB and found out the following:-
1. I haven't got the "Dual ETA" issue.
2. I've found that if you just load a destination, the red button appears and beeps if you press it but nothing happens however, if you select a second destination and make it a way point...then press the red button you get:-
If you then select the way point:-
And then press the black arrow in the left hand box you will find "1" in place of the red button and the ETA and journey time now reflect the run to "waypoint 1"... like this:-
I hope this helps.
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #492688 Mon Apr 04 2016 8:14pm
pko
thanks scrumps. I'll try that & see what happens.
regards
p
Post #492751 Tue Apr 05 2016 10:22am
pko
hi scrumps. I've tried what you suggested, it does do as you state yours does, but it doesn't solve the dual eta issue. That is still there, or not there, on all screens.
It seems odd that so few cars are affected.
thanks for your input.
kindest regards
p
Post #492755 Tue Apr 05 2016 11:01am
