Home > Maintenance & Modifications > tdv8 hst gearbox plastic filter/sump change |
Jylee Member Since: 28 Jan 2016 Location: Sugar land, TX Posts: 26 |
I used two jacks. Both jacks at motor mount and transmission need to be lifted. |
Mon Mar 28 2016 9:44pm |
Phils Hst Member Since: 22 Nov 2015 Location: newcastle Posts: 9 |
I dropped the whole car onto to stands under engine and box they wouldn't go high enough |
Tue Mar 29 2016 6:07pm |
this is what I do.. Rise truck to the highest off-road position, place 4 jack stands on truck frame, after cross member removed, and undo right side motor mount bolt. Lift up (slowly) both jacks. My motor shifted about 1/4", I have to pry the motor to be alignment with motor mount and bolt hole. |
Wed Mar 30 2016 1:33pm |
