Home > Technical > Special Programs ???? |
Special programs I would take to be the various settings for the various traction for snow, mud, ruts etc.
Tue Mar 29 2016 7:15pm |
You probably don't do many miles in it, or you've put an underpowered battery in it.
Tue Mar 29 2016 7:55pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 949 |
Do a search on here for special programs,,, lots of threads as its a topic that frequently arises. Battery issues are one of the more common faults but blown lamps or cheap non landrover replacements can cause issues. abs sensors or the wiring leading to them has also been found to be a problem. 2010 RRS, TDV8
Tue Mar 29 2016 8:00pm |
dave421 Member Since: 01 Nov 2015 Location: Spalding Posts: 26 |
Hi everyone
Tue Mar 29 2016 8:01pm |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2793 |
Yes they do - if the battery charge allows it try scrolling through the special program's looking for the response on the instrument display whilst the vehicle is running but in P or N 16MY Estoril Blue SVR.............
Tue Mar 29 2016 8:09pm |
Hi
Tue Mar 29 2016 8:33pm |
below your gear selector there is a programme selector you toggle it left too right. This selects the various 4x4 capabilities for the terrain you wish to travel on - over 16MY Estoril Blue SVR.............
Tue Mar 29 2016 8:41pm |
HI
Tue Mar 29 2016 8:44pm |
As per Lrtopix
Tue Mar 29 2016 9:01pm |
Hi PEACHY
Tue Mar 29 2016 9:04pm |
R444SPT Member Since: 20 Mar 2015 Location: Offroad somewhere Posts: 217 |
Assumign the battery is ok, and it is just lack of drive time allowing the discharge you should consider a conditioning charger - CTEK do some great ones, and even better you can charge through the towing electrics if you have them (13 pin or 7S socket (not the N socket). - you can also hardwire a "comfort connector" into place. - Adapter for tow bar charging is available from the shop on here -
Wed Mar 30 2016 6:19am |
