Home > Off Topic > Reading glasses or Lens replacement surgery? |
wackyjim Member Since: 12 Nov 2009 Location: Tayside Posts: 265 |
Been using reading glasses for presbyopia for a while now but getting totally Censored ed off at the amount of times I keep losing them or leaving them in the car ,jacket pocket or wherever and wondered if getting lens replacement surgery was an option? I know there are several types of lenses and surgery offered by the likes of Optical Express and Optimax but none seem to guarantee 100% that reading glasses can be binned once and for all,however on doing a bit of research it seems that light adjustable lenses can do that http://www.londoneyehospital.com/treatment...able-lens/ Wondered if anyone here has had this particular procedure done or for that matter any of the procedures offered by Optical Express etc and what their opinions were on it? |
Sun Mar 27 2016 1:40pm |
Not sure if at all helpful, but I have had Laser surgery, Cataracts removed, and have Retinopathy.
Sun Mar 27 2016 9:45pm |
Thanks Guys I guess there is still no perfect solution yet and there will always be some compromises with the currently available procedures , technology is always coming up with new developments so maybe waiting a little while longer might be sensible |
Tue Mar 29 2016 7:30pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9005 |
I'm struggling to see how a replacement lens can deal with the loss of accommodation as the eye ages. The lens needs to be flexible and connected to the eye's own mechanism for changing focus. The light adjusted lens is said to be set to overcome short or long sight and astigmatism. How it can also overcome the loss of accommodation is not obvious. I assume they shape the lens so that you look through different bits of the lens depending on how far away is the object being viewed. 2012 SDV6 - it's missing a couple of cylinders
Tue Mar 29 2016 9:31pm |
It's difficult to explain, but if your interested, read the British Diabetic site, as eyes are a big problem for diabetics, and many need new lenses amongst other things. Your new lenses are made to your prescription, but as I stated earlier can't normally be done for both long and short sightedness. It can be like looking through a pin hole to see what's in focus before. Periferal vision is one of the reasons for these being changed, and laser treatment isn't enough for permanent results and a operation under local anaesthetic is done takes around average 30 minutes, it's very painful mainly due to the injections around the eye. the fluid behind the lens can also be changed, this helps clear the vision as well and removes cataracts. This is just a very basic outline as said. Hope it assists. John
Tue Mar 29 2016 9:47pm |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 |
I too get pee'd off by having to wear glasses. Its the thing about advancing older age that annoys me the most. I'm quite good at not forgetting/losing glasses but that's because they are constantly perched on my head! I wander around with them resting on top of my head, like sunnies, lifting them up/down when I need to read something. Or if I leave them in my pocket, peer at things from a distance.
Thu Apr 07 2016 1:08pm |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
You only have one pair of eyes
Thu Apr 07 2016 2:46pm |
