![]() | Home > General > Electric windows |
Woppyman Member Since: 08 Jul 2015 Location: England Posts: 55 ![]() ![]() ![]() |
I had this last week. There is a reset procedure,
Is the same using both switches ? Can you here the motor clicking when you operate the switch ? If yes to both these questions then would suspect the window regulator rather than the motor. Strip door and investigate 2008 G4 RRSport TDV8 current
Graz Member Since: 22 Apr 2013 Location: Essex Posts: 104 ![]() ![]() |
Hi. It's the passenger window. All other windows are fine but the passenger window will not operate by either the switch on the passenger door or the the drivers door. There is no noise or clicking though when operated. |
Have you checked fuses, wouldn't expect fuses for individual Windows but who knows worth checking. After that would check to see if there is power going through the switch to the motor. 2008 G4 RRSport TDV8 current
