Home > Maintenance & Modifications > 2006 cam belt replacement
sixfootfourinches
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
Just become a new owner of a 2006 Range Rover Sport HSE 2.7 the car is 10 years old and has 62k miles on the clock, range rover suggest that the timing belt is changed at 7 years or 100k miles it was not replaced by the original owner, so should I do it now or wait until 100k miles?
Appreciate your response
Post #491442 Mon Mar 21 2016 10:41am
davidsherry33l
United Kingdom 2007 Range Rover Sport TDV6 HSE Santorini Black
get it done now and what ever you do get the oil pump changed also , my belts were changed just before i bought the car and they never changed the oil pump, 6 weeks later .... the oil pump failed which is quite common = New engine !! thank god i was under warranty ! read all the posts on here regarding this problem
Post #491443 Mon Mar 21 2016 10:53am
As above, get the belts and oil pump done. Do it now.
Be worth checking what else wasn't done on the correct schedule and get that done too. 2012 SDV6 - it's missing a couple of cylinders
Post #491454 Mon Mar 21 2016 12:52pm
