![]() | Home > In Car Electronics > Rear screen dash cam. |
the_big_1 Member Since: 04 Jul 2014 Location: Warwickshire Posts: 577 ![]() ![]() ![]() |
As above have the twin camera set up, biggest problem was routing the cable to rear camera with the split tailgate but I think yours will be a one piece so will be a lot easier to route .. 2008 G4 RRSport TDV8 current
duvl Member Since: 21 Oct 2015 Location: Surrey Posts: 38 ![]() ![]() |
Copied below from my posting here - http://www.rrsport.co.uk/forum/topic41688-45.html
This is all the cable you see of my Rear Cam.
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
I did mine on a split similar to Col, you can only see a teeny bit of cable. I threaded mine across the roof lining and down the A-Pillar to the back of the glove box, where I have my control unit. It was really simple to do. |
tarkuk Member Since: 19 Feb 2016 Location: London Posts: 26 ![]() ![]() ![]() |
hi all
On the 2008, it's a split tailgate which adds to the challenge as you need to feed it through two separate tightly packed rubber grommet/conduits. Made the more difficult as the power connector is 90degree angle. Bodsys Brake Bible
When I did my previous Sport with the split tailgate I just pushed a bit of single core cable through first and taped it to the blackvue coax cable so you could pull and push at same time, with a bit of silicone spray as well it wasn't to bad to get through.
so even with the split tail gate the trim is simple to pull of ? I had a little tug over the weekend just would not budge and don't want breaking the trim as the part prob cost an arm and a leg
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
I am a bit worried that the lack of sunshine is affecting some of you in the UK.
everyone needs a tug one in a while |
You need to pull harder if it breaks it's only £15.00 for a new bit. Cheers Col |
