Home > General (L494) > Low Battery Warning |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 |
I would suspect your usage pattern means your battery is having a very hard time, and could well need "topping up". MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Thu Mar 17 2016 1:38pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 949 |
Definitely get yourself a smart charger,,, Ctek are quite popular, and give it a boost overnight once a week, have had to do the same with mine as short journeys weren't doing it any favours. 2010 RRS, TDV8
Thu Mar 17 2016 3:02pm |
ravingmad Member Since: 23 May 2013 Location: Essex Posts: 331 |
Ditto the above.
Thu Mar 17 2016 3:05pm |
R444SPT Member Since: 20 Mar 2015 Location: Offroad somewhere Posts: 217 |
Love th ctek - even better it conn CTS via 13 pin towing socket!! |
Thu Mar 17 2016 4:51pm |
Dave777 Member Since: 15 Feb 2015 Location: Sussex Posts: 485 |
Did you get the towing socket charger from the guy on the Disco 4 forum? I assume the electric tow bar is 13 pin?
Thu Mar 17 2016 5:09pm |
Just used the shop link from the home page of this forum - really quick delivery - suspect same source as Disco 4 forum. |
Thu Mar 17 2016 5:15pm |
Thanks, I assume the L494 is 13 pin? I haven't used it yet! And it is a permanent live connection so can be plugged in with car locked? MY16 3.0 SDV6 Autobiography in Aleutian silver, stealth pack and toys. |
Thu Mar 17 2016 6:01pm |
Yes , if factory or Dealer fit, it will be 13 pin,many have a live in there, haven't looked to see which one mind you, it all just worked |
Thu Mar 17 2016 6:52pm |
Brilliant I will get an order in. MY16 3.0 SDV6 Autobiography in Aleutian silver, stealth pack and toys. |
Thu Mar 17 2016 9:39pm |
