![]() | Home > General > Start Stop button |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796 ![]() ![]() |
Welcome to the forum |
Relayer Member Since: 05 Mar 2016 Location: Norfolk Posts: 6 ![]() ![]() |
Ewoke is an auto |
Just copied this from the owners manual -
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
I just put my foot on the brake pedal then press stop/start button, haven't really noticed any delay in starting.
Just tried pressing button once as per above but nothing - the Sport will not start unless the button stays pressed & the brake pedal is pressed - i wait for the "checking system" message to finish which then prompts the brake pedal message |
Hi Peachy , yeah mines the S/C.
BiffoBear Member Since: 23 Feb 2016 Location: Bucks Posts: 51 ![]() ![]() |
Before getting my Sport (diesel, auto), I had an Evoque (diesel, auto) and that started with just a quick press and release of the button. The Sport is definitely different and needs the button to be held in for longer. Took me a few weeks to get used to it after the Evoque.
Mr Rusty Member Since: 17 Jan 2016 Location: Aberdeen Posts: 376 ![]() ![]() ![]() |
Yeah mine is the same, slight delay in starting. I guess it depends on temp as glow plugs need to heat.
As above,, there is a delay on mine but as has been said, it's dependant on temp, as long as you keep the brake pedal pressed it will start with just a momentary press. When stopping I can press the button without being in the car and it's stops straight away 2010 RRS, TDV8
As above with the delay on mine, when in the Alps in January in some very cold temps of -14 there was a noticeably longer delay, where I would think that it heated the glow plugs for longer due to temperature first thing in the mornings |
Thanks for all your comments but thought I'd give an update.
The rear cabin lights on the C pillar are manual switched only. Annoying but that's how they come out of the factory |
I've been told there is a Mod on here for having all the lights come on/off together, but you have to do a bit of soldering (no problems there) but I'm |
Further to above post, member kindly posted up the link, think I'm going to do this anyway this weekend.
