![]() | Home > Technical > How to detect a Turbo may be on its way out ? |
MattEdwards13 Member Since: 29 Dec 2015 Location: Wolverhampton Posts: 7 ![]() ![]() ![]() |
Ive just had my turbo changed on my 2.7 v6 as it goes, but luckily i had an oil leak coming from a pipe from the turbo running to the engine so i took it in and they determined it was turbo. They said to just monitor it but i didnt want to chance it so had it done. He said its hard to tell, one major thing to look for is lag when you put your foot to the floor does it take longer than usual to get that 'back in the seat' motion'. As i had noticed this also. Check oil levels aswel. If you're losing oil it could be going into the turbo n f***in stuff up! Hope this helps |
