Home > Technical > Aux heater remote issue
Shogan91
England 2011 Range Rover Sport 3.0 TDV6 Autobiography Java Black
Hi all,
This may have been answered but I can't find anything about it so long story short....
I have a 2011 TDv6 autobiography and it has the pre heat function with remote.
The remote has been fine all winter I press it it heats the car no drama.
Lately it's stopped working and when I press the on button it flashes green approx 8 times and the off button flashes red approx 8 flashes I believe it's a T91 remote.
Is this because it cannot connect to the car and if so can re connect it myself? Or is this a totally different issue?
Any advice will be great as I've trawled Google and have found little information
Many thanks in advance
Post #490382 Tue Mar 08 2016 5:15pm
Bodsy
Site Sponsor
its lost its pariing for some reason. Remove the FBH fuse (possibly fuse 2 in the engine bay?) then when you put the fuse back in, press and hold the OFF button on the remote.
should then re-pair
Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #490386 Tue Mar 08 2016 6:00pm
Shogan91
Diamond mate I'll give it a try in the morning!
Thanks a lot! Thumbs Up
Post #490399 Tue Mar 08 2016 6:35pm
Shogan91
Just removed fuse two working like a dream again
Many thanks Bodsy
Post #490478 Wed Mar 09 2016 4:52pm
Bodsy
Site Sponsor
no problem. Thumbs Up Bodsys Brake Bible
See it HERE
Post #490481 Wed Mar 09 2016 5:50pm
