Home > Faults & Fixes > Dash temp sensor still not working. |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
The ambient sensor is behind the front grill on the lower cross member, you have to stick your hand down between the cross member and the air con rad to find it.
Wed Mar 09 2016 10:57am |
GAVBEY Member Since: 23 Dec 2014 Location: Livingston Posts: 10 |
The external temp works fine.
Wed Mar 09 2016 2:40pm |
It could be your Instrument pack that is at fault then, you need to check the wire's out to see if there is any breaks anywhere.
Wed Mar 09 2016 3:59pm |
Had a look at the workshop manual for you and it seems there is only one Engine Coolant Temp Sensor (ECT). See the extract in gallery here: http://www.rrsport.co.uk/gallery/albums/us...script.pdf If your engine is running well and the viscous fan is not running all the time then the signal to the ECU is probably good and as Flack suggests it all points to a fault with the instrument or the wiring. Unfortunately my copy of the workshop manual doesn't include any instructions for removal of the instrument pack. Hopefully someone else can chip in with some hints on that? 2008 MY Java Black TDV8 HSE |
Wed Mar 09 2016 4:21pm |
Thanks for all the help guys.
Thu Mar 10 2016 12:13am |
Here is a bit more information about the Coolant Temp Gauge from the manual:
Thu Mar 10 2016 6:02pm |
Now that is some reply. Thank you very much for that.
Thu Mar 10 2016 7:55pm |
Pure speculation - but as the instrument pack is listed as a module and is connected to the CAN system it probably needs coding to the car which makes swopping the whole unit problematic?
Fri Mar 11 2016 1:59pm |
still havnt got to the botom of this. im considering buying a new cluster / speedo.
Sat Mar 19 2016 6:19am |
