Home > Maintenance & Modifications > Service Indicator & bulb failure
1) having serviced the car, is there a way I can reset the service indicator?
I remember on a Rover 75 you could short two pins on the diagnostic port for a certain length of time depending which service you performed. This reset the service count down
2) Do 2005 RRS have bulb failure monitoring ? A little surprised that rear bulbs don't cause a dash message. Can't see it mentioned in the manual.
3) Behind the headlights are small 2 pin connectors (grey). Anyone know what these are for?
4) Behind the grill is a multi connector (orange wires?) Anyone know what this is for ?
Thank you
Post #489346 Sun Feb 28 2016 8:09pm
TomTerrain
United Kingdom 2006 Range Rover Sport Supercharged HST Java Black
For resetting the service indicator, see the sticky in the technical section 2006 Java Black HST Supercharged
Post #489363 Sun Feb 28 2016 9:53pm
Arh having read it and tried you can't actually reset it yourself on the sport
Post #489991 Fri Mar 04 2016 5:28pm
