Home > Faults & Fixes > O/s/f knocking noise help
Tizzard
Hi all. I brought a 2007 rrs last week and I've noticed that there is a knocking sound coming from the driver side front wheel when I go over small bumps in the road and I get the same sound while driving and shaking the steering wheel side to side... Could this be drop links or the anti roll bar bushes as the car had both genuine bottoms arms fitted 2months ago.
Any help would great full
Thanks Thumbs Up [/s]
Post #482133 Thu Dec 10 2015 5:17pm
Lsv
Netherlands
Jack the car up, wheel free from the ground and check the wheel bearing,upper and lower balljoints. My car had the same noise and ended up being the wheel bearing.
Post #488171 Fri Feb 19 2016 9:59pm
Lewis
United Kingdom 2008 Range Rover Sport TDV8 HSE Lux Stornoway Grey
Me too new wheel bearing sorted it out. Thumbs Up
Post #489878 Thu Mar 03 2016 12:10pm
Paddi
Re: O/s/f knocking noise help
Tizzard wrote:
I've noticed that there is a knocking sound coming from the driver side front wheel when I go over small bumps in the road and I get the same sound while driving and shaking the steering wheel side to side..[/s]
^^Classic worn ant-roll bar bushes symptoms.
Wheel bearing noise is present all the time vehicle is moving, not just over bumps, and is louder when cornering with the worn bearing on the 'outside' of the turn. 2008 MY Java Black TDV8 HSE
Post #489896 Thu Mar 03 2016 2:48pm
tom0311
United Kingdom 2009 Range Rover Sport Supercharged Autobiography Santorini Black
Exactly the same happening to me now. Not too bad, but a definite knock when I move the wheel left/right slightly. Also knocks a bit when going over small potholes, but not really over the large ones! The car had new front ARB bushes just before I got it, so thinking it might be wheel bearing or drop links? Is there any way I can tell without jacking the thing up? I've got a trolley jack but it's not man enough I don't think.
Post #496345 Tue May 17 2016 7:27pm
