Home > Technical > Suspension fault -
Citizen55
United Kingdom 2006 Range Rover Sport Supercharged Tonga Green
Suspension fault -
Hi guys,
Just up in Lake District at the moment and this fault code came up. Any ideas? The fluid level for stability control is on minimum so hopefully its just that but I'm a bit worried. If it is the levels, what fluid goes here and can i get it from a petrol station? Any particular grade etc?
Thanks, John
 2006 Range Rover Sport 4.2 s/c with Arden bodykit
Post #489426 Mon Feb 29 2016 5:08pm
Citizen55
OK an update; the next day, this morning, the car started with the fault present and then a short drive and the fault code disappeared. Got back home without any further problems.
Would still like to know what fluid I use, and specific grades etc, to top up the dynamic response levels.
thanks 2006 Range Rover Sport 4.2 s/c with Arden bodykit
Post #489666 Tue Mar 01 2016 10:08pm
TomTerrain
United Kingdom 2006 Range Rover Sport Supercharged HST Java Black
Don't know if it's the fluid level, that happened to me one day under hard braking, it went of on ongine restart! It's something to do with the active cornering! Mine seems to be fine now! 2006 Java Black HST Supercharged
Post #489749 Wed Mar 02 2016 5:45pm
Paddi
thanks
If you look in the Owner's Handbook buried in the middle you'll find in the 'Maintenance' chapter a 'Technical Specifications' section and within that a 'lubricants and fluids' sub-section.
Against 'Dynamic response fluid' you will find it states 'Texaco Cold Climate PAS fluid'.
You can buy this at your nearest Land Rover Dealership or search on eBay and buy it from an on-line vendor, or order it from Duckworths.
In typical Land Rover fashion of course it is labelled 'Land Rover Cold Climate Power Steering Fluid (no mention of Texaco). Rolling Eyes
There is probably a generic equivalent but after hearing horror stories about the perils of using the wrong fluid and how it ruins the seals and trashes your system and costs £9k to fix it I ain't taking no chances for the sake of a £20 bottle of fluid!! 2008 MY Java Black TDV8 HSE
Post #489750 Wed Mar 02 2016 6:01pm
