Home > Technical > Flat battery |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 |
Not true. If the battery is healthy and the system senses the timed climate is draining the battery too much it will cut the timed climate and there is still plenty of juice left to start the old girl. I have faced this scenario.
Wed Feb 24 2016 11:24pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8970 |
In my experience, the alternator follows the battery. Or rather the battery is a symptom of a poorly alternator. Be worth getting it all checked over. 2012 SDV6 - it's missing a couple of cylinders
Thu Feb 25 2016 8:21am |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 |
Hmm.
Thu Feb 25 2016 4:18pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Not necessarily...if the diodes are failing, you could get a perfectly acceptable voltage, but also excessive AC ripple and a battery drain, not that I'm saying that this should be the case. Visiting from DISCO3.CO.UK 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver |
Thu Feb 25 2016 4:26pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4939 |
Sounds on the low side to me. I would start looking at battery prices. I've known smart chargers say a battery is fine, which clearly isn't, so they aren't perfect. |
Thu Feb 25 2016 6:14pm |
My Ctek said my battery was charged after a few hours. Turned out to be about to die. New battery and alternator. 2012 SDV6 - it's missing a couple of cylinders
Thu Feb 25 2016 7:23pm |
Thanks for the replies, all.
Sat Feb 27 2016 6:08pm |
