Home > Maintenance & Modifications > Fuel Pump and filters - TDV8 |
Zeus Member Since: 23 Feb 2016 Location: Dumfriesshire Posts: 6 |
Sorry, I should have mentioned ...... No fault codes stored at all.
Tue Feb 23 2016 9:21am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
The HPFP is at the front of the TDV8, driven by a chain.
Tue Feb 23 2016 8:36pm |
Thanks.
Wed Feb 24 2016 12:11pm |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
Just a thought but if it was low fuel pressure wouldn't you get fault codes saying low rail fuel pressure ? Have you checked the oil level, oil in the air filter try removing the intake hoses and again check for oil. 2008 G4 RRSport TDV8 current
Wed Feb 24 2016 1:42pm |
Just another thought had you just filled up the old petrol instead of diesel trick 2008 G4 RRSport TDV8 current
Wed Feb 24 2016 1:44pm |
Thanks Camelrock - I appreciate the help
Wed Feb 24 2016 2:09pm |
You can check the fuel flow by disconnected the quick release connector and check the flow. I would change the fuel filter as a matter of course 2008 G4 RRSport TDV8 current
Wed Feb 24 2016 6:19pm |
An update.
Fri Feb 26 2016 1:55pm |
Small update.
Mon Mar 07 2016 2:22pm |
What have your various 'experts' been using to read the fault codes? A generic tool will only detect generic fault codes and TBH this of only limited use on a sophisticated beast such as the RRS.
Yes. Low pressure should give you a fault code P008700 and there are other codes associated with other components of the fuel charging system. Did you change the fuel filter as Camelrock suggested? Its an easy enough job. Just about possible in off-road height but better to raise up a bit with a jack. Did you check Fuse 1E and Fuel pump relay (both in the engine compartment junction box). These are the possible causes of non-start listed in the manual: Engine cranks, but does not start: Inertia fuel shutoff (IFS) switch Low/Contaminated fuel Air leakage Low-pressure fuel system fault Fuel pump module (lift pump) fault Blocked fuel filter Fuel volume regulator blocked/contaminated Fuel pressure control valve blocked/contaminated Fuel pump fault Crankshaft position (CKP) sensor and the checks to make: Check that the IFS switch has not tripped. (edit: Look under 'Fuel Cut-off' in the owner's handbook. Can be reset by turn key to position 0; wait one minute; turn to position II wait another 30 seconds; start engine.) Check the fuel level and condition. Draw off approximately 1 ltr (2.11 pints) of fuel and allow to stand for 1 minute. Check to make sure there is no separation of the fuel indicating water or other liquid in the fuel. Check the intake air system for leaks. Check the lift pump operation, check the low-pressure fuel system for leaks/damage. Check the fuel filter, check for DTCs indicating a fuel volume or pressure control valve fault. Check the fuel pump: REFER to: Fuel Charging and Controls (303-04D Fuel Charging and Controls - TDV8 3.6L Diesel, Diagnosis and Testing). Check the CKP sensor circuits. Refer to the electrical guides. Maybe some of the above will help find the problem? Good luck, let us know how it goes. 2008 MY Java Black TDV8 HSE |
Mon Mar 07 2016 4:17pm |
A lack of low pressure will cause a subsequent lack of high pressure |
Mon Mar 07 2016 5:34pm |
