![]() | Home > Maintenance & Modifications > Best engine oil |
I use castrol 5w30 A5 in mine oil and filter change every 5k.. 2008 G4 RRSport TDV8 current
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9029 ![]() ![]() ![]() |
How many miles do you do a year in your G4 Camelrock? 2012 SDV6 - it's missing a couple of cylinders
Hi RRSTDV8, I would say about 8/10k it varies as I use the 90 for computing to work. The G4 tends to be used more for longer runs, towing the caravan etc though I think where using the using it to drive down to Andorra again this year so that will put 2/3k on in one go.. 2008 G4 RRSport TDV8 current
